1 - 18 of 18 Posts
My 2007 GXP was totalled after being struck from behind by an Avalanche (Chevy Avalanche, absolutely no pun intended).
I have a GXP computer for sale, bought from and tuned by Perfomance AutoWerks. Its tuned for 91 octane. I paid over $500. Will sell for $300 plus actual cost of shipping. Located in Calgary, Alberta. PM me if interested.
aren't they locked to a vin? meaning if someone buys it they will have to take to dealer to get it changed to work on their car?
No. You can do a relearn.
Takes about 40 mins...
Requires nothing other than turnjng the car on and off a few times for like 10 mins each time.
You can email Dave at Pwerks for instructions.
There is no procedure at all. Just unplug the existing Ecm, plug in this one and you are good to go... Takes 1 minute, and no tools.
I think you are wrong...
Nope. You can only do "plug & play" with your own ECM, if putting in any other ECM you have to relearn the ECM.
This is for a GM vehicle (Chevy S-10), idk if it's universal for all GM:
1.Turn ON the ignition, with the engine OFF.
2.Attempt to start the engine, then release the key to ON, vehicle will not start.
3.Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
4.Turn OFF the ignition, and wait 5 seconds.
5.Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes, the vehicle is now ready
to relearn the Passlock(TM) Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
IMPORTANT: The vehicle learns the Passlock(TM) Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
6.Start the engine, the vehicle has now learned the Passlock(TM) Sensor Data Code and/or password. 7.With a scan tool, clear any DTCs if needed, history DTCs will self clear after 100 ignition cycles.
Nah nah...
I win.
Sorry, you are right. First time I did have to do something like this. So long ago I forgot. After the first time you can swap at will.
Anyway, if anyone wants it, let me know.
Is the ECM from manual or an auto?
Discussion Starter #12
If anyone wants this, make me an offer!
I also have a new-in-box OEM cupholder replacement kit that I never got around to installing, as well as spare key fob. Both are free with ECM purchase.
Discussion Starter #14
I ended up getting a 2009 Audi TTS droptop (with 10,700kms and warranty to 2019). I bought it because of Audi's great Quattro AWD system, which allows me to commute from Cochrane to Calgary year-round with winter tires (I only drove my Sol in the short summer we gt here, so had to have a second winter 4WD vehicle). This allows me to own one less vehicle and fit them all in my garage Like the Sol its a 2.0 turbo direct injection setup, and gives similar performance (around 265 hp).
The Audi is a great car, and in many ways I like the auto dual clutch, which is all the car comes with (no true manual) but do miss the greater connection you have when driving a true manual. Also, there is no way to rev the engine and dump the clutch from a standstill, so that reduces the fun factor to a not-insignificant extent.
Interestingly, although the Audi is well appointed from a fit & finish perspective, things like the "upgraded stereo" (Bose) are no better than the Solstice with Monsoon, and I would say that the Monsoon's subwoofer is significantly better. Also, the Audi has no boost guage capability whatsoever, which is a bummer and no oil life monitor (other than a strictly km based "time to change your oil" thing).
In terms of looks, the Solstice was a 9.5 and the Audi is about a 6.5. Just like a woman, the curves (or lack thereof) in the right places make all the difference...
The features that I sure do like in the Audi is a real trunk, functional roll bar and electric roof which can be raised and lowered while driving at low speed.
Anyway, if anyone wants my ECM and the other odds and ends, make me an offer as they are just sitting in my garage.
On his 1st post he wrote it was a 2007 GXP manual.
Discussion Starter #18
My car was a 2007, so the ECM was for that year (or at least programmed for that year, not sure).
1 - 18 of 18 Posts
