Here’s a little Christmas gift for my Sky and Solstice people. (lol)
I had to relocate my front sway bar on my car a few weeks ago and also did a little mod I figured I’d pass along. This is a little trick I learned WAY back when I had a ’74 Firebird and it needed a lot of help to make that ‘70’s suspension design a little less boaty. One of the things I did was to shorten the leverage point of the bar by moving the link mount hole. Shorter sway bar arm= more force needed to twist bar.
When I was making my sway bar brackets, my goal was more rigidity and more sway bar strength. The more ridged you make the mounts, the less free movement you get before the sway bar starts to actually work. The mounts I made are two-piece billet aluminum with 5 mounting bolts to hold it all together. I don’t think there will be much slop in the bar movement!
My other goal was to increase sway bar strength to help with the added V8 weight. Even though these bars aren’t like the old ‘70’s sway bars in that they’re hollow instead of solid bars, there’s still enough material at the ends of the bars to move the link mount hole. I was able to move the mount hole in an inch without compromising the bar end strength whatsoever. The pivot length of the front bar is about 7 inches stock, it’s now 6 inches on my front bar. (I plan on doing the same to the rear, haven’t gotten there yet.) That means I’ve increased the sway bar strength approximately 14.3% over the stock Z0K bar. If this ends up being too much for the front, all I’ll have to do is move the links to the stock, rear holes. I don’t think ~14% will be too much for the front or rear with the rest of the changes I’m making to the car.
The best part of this mod is IT’S FREE!!! If you can figure out how to remove a sway bar to replace it, then you can probably handle drilling a new hole and grinding away a little bit of the angle to make sure the link stud and nut fit flush with the bar. If you keep the new hole closer to the old one, you won’t even have to do anything else but drill the hole. That would get around a 10% increase in bar strength with very little work. I would be willing to bet the holes could be drilled without even removing the sway bar from the car. The worst that could happen is you’d destroy the bar (highly unlikely) and have to buy a new one. Best that can happen is you spend an hour or so in your garage and drive out with sway bars that are between 10% and 14% stiffer than stock FOR FREE! The added benefit is you still have a stock, GM made factory sway bar that is a know stiffness and you're doing a known and easily calculated increase to that stiffness.
Merry Christmas guys!
