that looks better than over the grill IMHO, but you would still have to have holes drilled, and i would rather wing it and pay the fine if i ever come accross a cop that is in a bad enough mood to actually ticket me for it.Continental Op said:I'm a bit ambivalent over where to place the front plate. I don't want to obscure the grillwork, but I'm also not interested in the legal attention that windshield-mounted plates attract. Has anyone considered a custom mount like this?
I agree. Center it in the grille so you can see honeycomb above it and below it. That will help the plate to fit in, kind of like its floating in the grille.solsticeman said:Move it to the upper part of the grille.
A bracket can be fabricated with a right angle, extending horizontally under the bottom of the body and attaching with fasteners vertically into body or frame. This is the option I plan on doing if I get a hard time from the copsswatthefly said:that looks better than over the grill IMHO, but you would still have to have holes drilled, and i would rather wing it and pay the fine if i ever come accross a cop that is in a bad enough mood to actually ticket me for it.
GNS said:A bracket can be fabricated with a right angle, extending horizontally under the bottom of the body and attaching with fasteners vertically into body or frame. This is the option I plan on doing if I get a hard time from the cops
Worst case scenario, the front bumper cover will have 2 very small dimples (not thru and thru,) that help the prep guys locate where to drill for the initial 2 holes for the rivets. Check out an Envoy or a full size truck/SUV to get an idea. They are hardly noticeable unless you get down to ground level and stare at them from an angle... unless of course they're drilled out.The Mayor said:The front mounting plate was an option that HAD to be added to my order since NJ requires one.
Does anyone know whether holes are drilled into the bumper assy or somewhere else to accomodate the mounting?
I'm hoping that is not the case so that I could remove the mounting plate. Being a Mayor sometimes can be beneficial......![]()
I'm guessing the dealer is required to say that, but if you say you're going to be registering it out of state, they can probably opt to leave it off the order. If so, they may ask you to put it in writing in order to cover their legal responsibilities. I wouldn't guarantee it, but I'm guessing they could get around it if they made a note to that effect in your file. (Of course, you'd have to be willing to tell a "little white lie" to pull it off.) Anybody else have any luck keeping the front plate off your order in a state that requires it?The Mayor said:The front mounting plate was an option that HAD to be added to my order since NJ requires one.
hyzer said:I think the dealer is only required to order the bracket with the car and give it to you. I already told my dealer I didn't want it mounted and he said he'd leave it in the car on the floor. I also requested no dealer sticker on the back too.
