1 - 6 of 6 Posts
Has anybody dealt with the speedometer, tach, fuel gauge, mpg, trip odometer, and security light coming on while driving. Stop turn it off and restart and it resets. It did this several times today.
Welcome to the forum. Any codes come up? Checked all the grounds?
Let me google that for you
Also, have you had your ignition switch recall done? Did the issue start after that? A bad ignition switch is another possibility.
Reactions: rob the elder
Do you still have the original battery in the car? If so, replace your original, when they start to get weak they start to cause all sorts of electrical gremlins. Have you tightened the grounding strap on the left corner of the engine? All of these and the above can cause this issue!
If you've done all that, and it still happens, there is a computer under the passenger floor, where the connectors can get wet if the top is down in the rain. I had to open the connectors to mine, clean the contacts with contact cleaner and a soft brush, and all is well again.
1 - 6 of 6 Posts
