So what's the benefit to this reservoir apart from larger capacity of brake fluid?
There is increased internal “baffling” / subsections which should also help with sloshing under spirited driving scenarios like track days…So what's the benefit to this reservoir apart from larger capacity of brake fluid?
Is the cap not sealing properly?
Are you gonna use both of those?Received the second brake reservoir today from the local Saab dealer; Scanwest Autosports in Seattle.
You would need filament that brake fluid won't attack and a way to seal the print, as they can be a bit porous.Are you gonna use both of those?
I found a used Saab one I will fit soon if I can't find new.
But seriously, is this something that could be made with a 3D printer? Not that I have that capability.
it is quite complex but i can imagine it could be, they can print houses...Are you gonna use both of those?
Which Saab did you get it from? There is a couple in the pull a part locally.Are you gonna use both of those?
