I am still working on the turn signals. I didn't like the speed they were running at so I had to break the strip into multiple pieces. There are a total of 10 strips now and 8 of them work in a manner that makes them look like a single strip. This is going to make the strip run a lot faster. I made the wiring harness for it and I have the lenses made and the LED's installed into the lenses. I am writing the software over again to handle the splitting apart of the strip.
I messed about with the lower radiator hose some more, I didn't like where I had the T for the overflow bottle. It was to mixed up into the ABS and A/C lines. Good news tho the system filled up without getting air bound!! YAY!!!!!!! The best thing is because I replaced all of the coolant lines with stainless steel I will never have to replace them.
I also started work on the fender liners and splitting them into an upper and lower section. They are cut. I have to add a few layers of fiberglass to the upper portions to make them stiffer so the 2 pieces will make a good seal. I changed the orientation of the overflow bottle so it didn't stick out so much over the top of the wheel well.
The CAI I purchased from Werks didn't fit. It was hitting the upper radiator hose. I put the OE upper radiator hose in to see if it would hit that and it did. So I busted out the sawzall and cut the thing into pieces I could use. I am waiting on a 90 degree elbow to finish the CAI, I should have it this Friday. I also had to move the CAI anywho because of somethign I did with the raim air hood, I explain more about that a couple lines down.
The wastegate if now fully installed, what a pain that was.
The catted downpipe is installed and I hooked up the OE exhaust until I can get it down to the exhaust shop to have a custom exhaust made.
The front frame brace is installed as well.
I added a duct to go from the ram air on the hood and it pipes into the duct for the radiator. Because I did a really good job at getting the intercooler and air dam installed so the only air the radiator sees is the air that comes out from the back side of the intercooler. This is a GREAT thing for getting rid of intercooler heat soak when the car is at an idle. The fan for the radiator is going to pull the air through the intercooler. It's a bad thing because the radiator doesn't see any cool air if the intercooler is hot. So I added that duct and inside of it there is a damper that will open only when there is a positive pressure on it from the ram air side. Otherwise it will stay closed, which means the car isn't moving and we want to cool down the intercooler using the radiator fan.
I am replacing the 13 year old OE battery with a 2600 CA stinger dry cell battery. This is probably going to be the last battery this car ever gets put into it. It is a smaller footprint then the OE battery and it's a few lbs lighter as well. It has a hell of a lot more cranking amps. the OE battery has 650 CA I believe. Because the battery is smaller I decided to make the battery parallel to the fender and shift it towards the door.
Changing and moving the battery opened up a pretty sizeable space under the fuse box and that space is even larger then normal because I had cleaned up the wiring spaghetti that GM had done there. Now there is a bee line right from the turbo to the fender vents I took the fuse box bracket out and cut some of it off where it was acting like a wall. I cut it down by about 1/2. I used fiberglass heat shield on the wheel well liner and I made a sheet metal bottom side and top to protect the wires and fuse box and the heater box. This should work like a champ at removing heat from the turbo area when the car is in motion. The air moving down the side of the vehicle should cause a negative pressure area where the vents are and air should be sucked out from the vents.
Here are some more photos of my progress.
Vent under the fuse box.
vent that goes to the ram air along with the final version of the hold down bracket for the bumper cover.
Lots and lots of extremely expensive DEI heat sleeves, and heat shielding. The shielding covers the entire heater box and covers the firewall from the heater box to about the middle of the engine.
This is a good photo showing what I did with the wiring and hoses running across the front of the engine.
The CAI pipe that is attached to the filter is going to run parallel to the radiator and then make a 90 degree turn and head down to the front of the car.
This is where the air cleaner is going to sit.
I like this photo, I think because it shows how complex the piping is. The amazing thing is not a single piece of it touches anything else.
You can also see where I marked the hood for where the piece of fender liner is going to sit.
