1 - 1 of 1 Posts
I recently installed a Spec Stage 3+ clutch in my 06 Sol with a new, stock flywheel and throwout bearing. Now, I have a loud grinding noise when I let off the gas in 4th gear and faintly in 3rd gear, all others seem normal. Under acceleration and braking, there is no noise, but coasting is unbearable. Has anyone else had this problem or have any idea as to what it might be? It sounds like its coming from the transmission and is not the normal differential whine. I have replaced the fluid in both the transmission and diff, and have replaced both motor mounts to try to get rid of the noise.
1 - 1 of 1 Posts
