I have a 2007 Solstice GXP. (one of the first ones in AZ) It has a little over 50K miles on it. Everything is stock on it except the antenna. A few months back I took it for a drive and although it started fine, once I went around the corner it would sputter whenever I gave it gas. I limped back home and parked it till I had a chance to spend more time on it. Long story short it sat for about 6 weeks. I started it up one more time, it would idle fine, I could rev the engine fine, but as soon as I tried driving it would sputter. After doing some research on the forum I discovered the little plastic offshoot on the main intake hose had been broken clean off. While waiting for the part to come in I realized my car wouldn't start anymore. I got the part, installed it, and also took this opportunity to replace the spark plugs for the first time. (Yeah, they had a lot of carbon buildup) Put everything back together and was devastated to find the engine still won’t start. It turns over, but doesn't even get close to starting. It’s almost as if the engine isn't getting any gas. I've reset the computer thinking maybe it had been overcompensating due to the broken intake, but still no luck. I also threw one code: P0336 “Crankshaft Position Sensor Performance”. Any ideas or suggestions?
