1 - 13 of 13 Posts
Just curious, I just got my 2007 GXP and the radio channels have a lot of static. I see the previous owner put on a shorty antenna. Does that usually not work well? Is there a preferred antenna? Thanks
I tried the shorty. It looks great but reception really sucks. Finally went with the opel antenna. Not quite as good as the OE antenna but good enough for your locl stations. Still keep my OE antenna in the boot for long trips.
I did the same, tried the shorty and then went to an Opel GT antenna. The shorty didn't get anything but the most local of stations.
If you have a phone charger (or similar device) plugged up, remove it.
I tried a signal booster on my stubby and found that it boosts everything. static, signal loss, fading, etc. You get every disadvantage of a stubby, only louder.
Is there anything on the airwaves worth listening to? Maybe weather and/or traffic if I'm on a trip.
Bought a Sony media player with a 256 gb SD card - listen to just about everything I own in full lossless.
Nine and a half thousand songs on an SD card. It isn't lossless, but it is playing in a convertible with the top down so it really doesn't matter.
I printed a cap for the antenna stud, and keep the antenna in the trunk in case of an "emergency".
Thanks for the response.My antenna is like 3 inches tall.I activated the XM.Ill get a different antenna
The "stubby" isn't really an antenna; it's just a decoration to cover the antenna base. I got an inexpensive Opel-like universal antenna at an auto parts store that works OK, but I listen to XM almost exclusively.
I'm still using the factory antenna on my '09 coupe. My preferred FM station is 50 miles away. With the coupe top removed my radio reception drops off significantly. Any other coupe owners notice this problem?
1 - 13 of 13 Posts
