1 - 20 of 28 Posts
Hey guys, 07 GXP is stock besides Trifecta Budget Tune (really love it!) was thinking about a K&N Typhoon CAI for my next upgrade, I was wondering if it would throw anything off with the tune? I understand I probably won't make any/much performance gains from the CAI, but I really like the "breathing" sound (intake and BOV) the car makes, and I have heard this increases
Sound. Basically, I'm just wanting to know if the CAI will not mess up any
Type of timing with my budget tune...I do plan to add more mods and will have to retune in the future, but for now, will it be fine? What can I expect sound or performance wise from this install?
You will most probably be okay. I was okay with GMPP intake. K&N intakes in my experience usually are okay without a tune. If you go with another intake, or notice drivability issues at idle etc., you may need to upgrade to a datalogged tune or see if maybe you can switch to a ECP Budget tune that does not use the MAF. Your Trifecta dealer can help you.
I had a CAI on my GXP and was an interested observer when there were a LOT of threads discussing the utility of a CAI.
The end result was
1) GM powertrain engineers made it clear that the factory filter was very efficient and not a limiting factor on HP
2) Several people with tuned cars noted that the CAI did not provide any measurable improvement in performance
3) The CAI is not truely a CAI as they all take in air from the same location as the factory airbox
4) One member ran tests and found that once the car is in motion, the temperature at the intake for either the CAI or the factory airbox is essentially ambient temperature
5) All CAIs eliminate the sound trapping design provided by the factory airbox and as a result you get a lot of intake noise that some find disturbing
6) Some CAIs were found to actually reduce performance
7) Several members noted that using an oiled aircleaner element resulted in MAF contamination. This elicited a lot of discussion.
The consensus opinion I came away with was that I would not use an oiled filter element, that the CAI isnt, that there is little or perhaps no improvement in performance and I can testify to a lot of intake noise.
:thumbs::willy::thumbs:
Thank you Rob, can I ask which brand CAI you had/have? Seeing as how Solos Hi-Flow Cat is around the same price...would this be a better option and would I be able to use it with the budget tune for a while? Also would the hi flow cat make the exhaust (stock) louder?
FWIW, I had both GMPP and AEM intakes at different times. Both used non-oiled filters. Both had minimal to no effect on horsepower. Both made a lot of extra intake noise.
I'm back to a completely stock intake.
Someone else will have to address whether the Solo Hi-Flow cat will work with the budget tune. It will make the exhaust sound louder.
It seems like no one had really been happy with their CAI purchase...would a louder exhaust drown out the louder intake noise from a CAI?
I had the Dejon CAI. I liked it but it was cosmetic more than anything else.
The high flow cat is one of the few after market bits of hardware that actually provide increased performance. I saw +18 HP after the GMPP tune unlock. The "accepted" range is 16 - 18 + hp.
I dont have any specific knowledge about how the increased flow affects your specific tune. But I suspect that it is great enough that it will probably need to be accounted for in the tune data. If you have already installed the tune, talk with the tuner and ask him directly.
I highly recommend the Solo HF cat.:thumbs:
I bought mine before there was a lot of experential information on the forums. As soon as I started the car after installing it, I immediatenly understood what others were complaining about. At start, there is a giant sucking sound as the ECM calibrates the MAF sensor inputs. It sounds . . . bad. If you wait it will steay down and go back to a more normal intake sound, or if you blip the throttle it will go back to a more normal sound.
When ever you put your foot into the throttle and let off to shift, you get a very loud blast of sound as the building boost is shut off by the intake valve. It was so disconcerting that for the first 2-3 days I was convinced that I was going to pull the CAI and reinstall the stock airbox. But I found over time that I grew to accept if not particularly like the sound and it was just easier to leave it as is.
Thank you again Rob! I have heard (and no disrespect to Dejon at all) that the Dejon CAI does increase noise possibly more so than the K&N , do you have any experience with hearing a solstice with the K&N typhoon CAI? I think I may make the Hi Flow Cat my choice for now , over the CAI
The issue is the oil on the K&N filter. I had the K&N dropping filter and had to take it off because of the oil residue in the MAF. I was very careful when installing the filter making sure there was no excessive oil on it. After a few weeks of use the problems with the MAF showed up. Put the OEM filter back on and has been there for a long time with no issues. Performance was the same
As others have said the Hi Flow cat will be by far a better investment for you.
You do need to talk to Vince and see if the budget tune needs any changes.
Discussion Starter #12
Ok thank you guys...LV, would the changes be just to see a better gain, or would they be something that if I did not retune, it could hurt my car
Ditto on going with the Solo High Flow cat. Plus much less chance of it affecting the tune if at all.
Discussion Starter #14
Guess I'll be going Solo! CAI can wait, if at all...now just gonna hoPe they have a holiday sale :)
I think you will like the Solo cat.
There is at least one good video on Youtube about R&Ring the cat that is good to watch. If you are doing it yourself, while the video shows jacking up the engine to gain clearance, many have swapped out their cats without jacking the engine. It is an interesting challenge but it can be done.
Also, make sure that the O2 extension tube is installed on the sensor AFTER the cat and you will have no problems. When we did mine, the instructions were text only and a bit ambiguous so we did it incorrectly.
I wouldn't bother getting a CAI at all, unless you want the increased noise or simply want to clean up the under hood appearance and eliminate the plastic tube spigot that frequently breaks when changing a filter.
The high flow CAT is a good bit of gear and works just fine with the GMPP tune, although I don't think it gives you as much as 18 bhp on top of that tune, more like 10. Either way, you will have an increase in exhaust noise, so do this on its own and see how you like it, before considering any other exhaust changes. Some of the free flow exhausts in combination with the high flow CAT can result in excessive noise.
Frankly, after the CAT replacement, I'd concentrate on handling improvements, if you are the type that appreciates such things. Let us know how you drive and we can make some other suggestions.
Discussion Starter #17
I'm not really sure what category my driving is in...basically, I drive normal for the most part...but I do get on it quite often, but normally short spurts (50mph-100mph...30-80...things like that) I do have some very curvy roads around here, but I havnt really explored them with my sol...I like accelerating fast, I guess that's my type of driving, and I like coming out of corners fast, and I guess I do normally take corners faster than most...only if it's dry of course
Discussion Starter #18
I've asked before, and have been answered, but last time... Can someone explain the functions of each separately : probeam, backbone, and LVs (front brace I believe)
Yes just to see if the basic tune will adjust itself to the new found cat.
Adding the high flow cat should not have any adverse issues with the tune in my opinion.
However you should just check with Vince, he is just a phone call away.
What those three mods do is tighten the chassis to reduce flex, letting the rest of the suspension do their job. You feel the car has lot more control while you drive. These is a very quick explanation rather than going into a more detail description of each.
By the way the LV front brace is now sold exclusively by DDM, so you can have a one stop shop for all three items.
These are one of the best mods you can do to the car that will help the way the car feels and behave.
If you want to go further with the suspension then you have to get into better shocks and sway bars plus TIRES.
1 - 20 of 28 Posts
