After getting numerous P0101 codes, I changed out some of the stock clamps with more heavy duty t-bolt clamps and it seemed to remedy the problem. I recently noticed some "lurching" at around 2300 RPM and thought it maybe due to poor fuel quality,but after burning through different filling sites the problem still continued. When I would push the car to higher RPM's with full boost (22-23psi) it would sometimes hesitate and go into a low boost mode. The other week, after heavy acceleration, it said service ESC and then the engine light came on again, and it would only boost to 6psi. After restarting the vehicle, the engine light remained on but the boost would still climb all the way to 22-23psi. What is causing this code to be thrown? I have the GM tune since I've owned the Solstice GXP.
Help!
Ed
Help!
Ed
