1 - 4 of 4 Posts
Been doing a lot of reading and research and ready to start tuning with hp tuners. I have the WB setup and custom AFR error PID for that.
Problem is, I can't find a VE table or MAF fueling table.
Do 2006 LE5 ECUs even have a VE table? If so, where is it?
For MAF tuning, what tables should I be using to adjust to AFR error data?
Thank you!
2007 Solstice GXP
You can't use that EQ program to tune your speed density. The LE5 uses a different calculation.
Your best method is to disable VE and do a MAF only tune. You will get great results by doing that. To do this you set the dynamic airflow high rpm disable to 0 and the re enable to 8192. You also need 60lb inj data for your tune as well. Theres a lot more to it than that though. There are some pretty good LE5 walkthroughs that are pretty old. I think one is on the Ion forum. Prob a ton of info on the cobalt forum as well. I had a SC LE5 car a few years ago so its hard to remember everything, but I still have all my tunes.
1 - 4 of 4 Posts
