1 - 7 of 7 Posts
My Stereo is dead. I checked the wires and have no power to the battery wire. I can't locate any fuse for the stereo to even check. The space that the manual shows for stereo fuse in 23 is empty. Its a 2007 GXP.
Any help would be appreciated.
Thanks
Thanks
You are looking at the fuse box under the passenger footboard, right?
#23 in the fusebox under the hood is normally empty.
From the owner's manual page 327:
Floor Console Fuse Block
The floor console fuse block is located on the
passenger’s side of the vehicle under the carpet.
Remove the fuse block cover to access the
fuses. Use the fuse puller to remove fuses.
After re-installing the fuse block cover, be sure to
tuck the carpet under the heater floor outlets.
Hope this helps.
:thumbs:
If I remember correctly it was a small amp fuse either 2 or 3 amp that is in the box on the passenger side floor.
I am trying to replace an aftermarket head unit with an updated one in a 2007 solstice gxp and everything is working except that a have no sound from the speakers. I suspect that the monsoon amp is not turning on and don’t know why. Am I missing a bad fuse somewhere? I have checked the fuse block under the hood and the interior one in the passenger footwell.
1 - 7 of 7 Posts
