Hello ALL! I have four questions/problems I'm trying to answer/solve...1) Has anyone had and successfully solved a "Service Airbag" message? 2) Has anyone had and successfully solved a repeated "Key Fob Battery Low" message? Before you answer, I have already replaced the battery three times (and tested the "old" battery which read fine.) in a month. 3) Has anyone used an effective heavy duty convertible top cleaner? I can't get my convertible top "clean." It seems to have a "waxy" coating on it that won't wash away but loves to collect dust, dirt and pollen. I have tried three reputable top cleaners with no luck (Turtle Wax, Mothers, and 303). Lastly 4)
Has anyone experienced and solved intermittent HVAC temp issues? There is a clicking coming from inside the driver's side dash and the temp randomly gets stuck on hot or cold regardless of position and fan settings. There are two "actuator" parts: one appears to have a "male" gear and the other a "female" gear, both seem to have the same shape. Air Conditioning Vacuum Actuator, Part Number: 10397102 and Temperature Mode Valve Actuator Assembly, Part Number: 10397365., each about $25 new from GM. I can also get a used Climate control panel for about $75, but don't want to just throw parts at the issue.
I look forward to some insightful answers from the group. I have already scoured the Solstice forums but have not found conclusive answers.
gmpartsdirect.com
2006-2010 GM Temperature Mode Valve Actuator Assembly 10397365 | GMPartsDirect.com
2006-2010 GM part # 10397365 - Temperature Mode Valve Actuator Assembly
gmpartsdirect.com
