I read a few threads trying to find a answer to this, 2008 GXP, 32k miles, automatic
Running operating temp: 200*f (205* if i stay stopped at a light for a long time)
Issue:
- Will not blow hot air at all regardless of what temp you have it set to, at first, it would blow cold air when set all the way to the left, than one click to the right it would go full heat. Well that didn't last long, the next day it stopped heat all together regardless of dial position
What I've tried:
- Franticly move dial left to right like a mad man trying to get some heat: FAILED
- Did the recalibration process 3x: Failed
- Checked every single HVAC fuse/relay: all good
Im at a lost now on what to try next, i have a spare HVAC control panel I'm going to try and swap in later today, do a recalibration for it and see if it works. Anyone else have any ideas?
Issue:
What I've tried:
