I'm trying to do a clutch swap on my 2006 Sol, and am now stuck trying to separate the Propeller shaft from the back of the Trans.
(I'll post a pic as soon as I figure out how)
I was able to separate the back half of the propeller shaft from the rear Diff by removing the rear portion of the exhaust system, then unbolting and lowering the differential enough to allow the two to be separated. The front half doesn't want to come off quite as "simple". I've removed all the bolts, sprayed it with penetrating oil, but it doesn't budge.
Does anyone know the trick to getting this out?
