1 - 7 of 7 Posts
Good morning all,
Here's a quick question for anyone who's installed HIDs. I ordered a light kit from HIDExtra and everything came as expected bulbs and ballasts. When I tried to connect their bulb to the connector from the car it's too small and gets blocked by a little green gasket. I've tried to push it past but no luck. I wanted to know if this is common with the H13 bulb or is it just this manufacturer and I should try another? Or if it's not a big deal can I just shave the gasket down to make it fit (I'm not sure if it's to keep out moisture). Thanks in advance for your help!
Make sure the pins are lining up if not it wont push past the gasket, fix is to bend the pins a little so they line up right. Also there should be a "key tab" that sets the polarity make sure you have this in the correct position.
Pictures of both male and female terminals would be helpful to give you advise.
--Christian
I found the following with my HID plug. You may have the same issue (a Dremel is your friend!):
Thanks for your responses. I took a closer look at the 2 bases and realized that in the new bulb, there's a piece of plastic for stability i'm assuming that runs inside the connector that's blocking it from making a full connection. It sucks, but these are going back as I'd rather not modify the connector coming from the car. I guess all H13s aren't created equal...
Happy Driving.
Nyika
SaME problem
Happy Driving.
Nyika
I am having the same problem. What company did you go with in order to have Hid headlights. thanks jmac
In fairness to OEM Stability and 'warranty'....most should not do this.
But if you want a reliable connection, I say, line up the plus, match wires, cut pigtails and solder wires.....
Every single H13 kit I've ever installed (I've installed a fair share, on many different vehicles) I've only had 2 or 3 maybe that have fit 100% without issues....it seems as though all manufacturers made their own H13 plugs without thinking of the aftermarket
Anyone that has an HID kit in their solstice and would like to have spare parts can send me a PM. I have bulbs, ballast, and cancelers for both the 35W and 55W.
1 - 7 of 7 Posts
