1 - 4 of 4 Posts
I had my mechanic install the Curt hitch #11119 as recommended in the sticky on the top of this forum, but now my 2006 Solstice (base) makes a very loud rattling noise from the rear of the car when idling and compression braking (I don't compression brake ever, but I did some tests and shifting into 2nd at 30 mph and putting the car in gear made the most unholy rattling noise). It is very loud and intrusive, and I cannot imagine that anyone would be willing to live with this. Additionally, and less bothersome, is that it creaks when I make turns at low speed. This is all with nothing attached to the receiver.
Has anyone had experience with this or know what went wrong?
After I installed my Curt hitch on my 2.4 I had a bit if a knock over bumpy roads. One of the hanger brackets was contacting the hitch. I heated the bracket and bent it in a little. Problem solved.
It sounds like the hitch is contacting the muffler.
Yep - this happened to me too... I tightened things up, and added some rudder-ish padding...
1 - 4 of 4 Posts
