1 - 4 of 4 Posts
Hi, does anyone know if the floor under the seats are hollow or single sheet metal?
I ran over a brick and it put a dent in the underside. I tried pulling it out from underneath with a dent puller but I can't get all of it. Thought I could remove the carpet and get to it. But if it is a dual sheet metal hollow floor it won't work.
Thanks.
Sent from my useless Autoguide iPad app
Pretty sure its single. Easy to get to once seat is out. Carpet has thick (very) padding underneath so you prob wont feel dent from top
Ok thanks. I'll find the time this summer to pull the seat out and try to push I out.
Cheers!
Good luck.
Wouldn't bother at this point, let it be. Pounding on it from the top could_? further weaken that spot. Oh, and you're lucky that after running over a brick you sustained very minimal damage compared to what could have happened.
1 - 4 of 4 Posts
