This pretty much describes what happened when I detonated my rear diff at my last autocross event of the season.
Let this be a warning to those that drag race or do hard launches at autocrosses. Here is the sceanario: It was a somewhat cool Maine day, temps only reaching about 60 degrees, the concrete surface was cool but still grippier than pavement. The particular event this day had what we would call "a drag strip" start...a long straight right out of the start box to the first cone...not normally something that has occured at past events (fyi). We had a problem on course after our first run and a small section of the concrete was breaking up for some reason. We had to do a small course change which meant a safety run after implementing the change. The event chair asked if I could run that section at speed to determine if the change was subtle but safe. I made two passes with the chair in the car. Now my tires (Hoosier A6s) have heat in them and thus more grip...a detail I had forgotten about.
On my first run of the morning I had minor tire spin at the launch because the tires and surface were cold so launching wasn't a problem. When I got back in line to do my 2nd run I launched hard because I wanted a more aggressive start than my first run and also wanted to improve my time. The warm tires hooked up, spun, hooked up, spun, etc. which started a "hopping" feel in the rear end. Rather than back off the throttle I stayed in it thinking that the tires would eventually just hook up and I'd be off...WRONG! About the fourth or fifth "hop" there was a loud BANG. I knew right away what it was...a blown rear diff. I started to limp the car back to the paddock and heard some rather disconcerting crunching noises and then silence...the car was dead in the water. Got some buddies to push the car up onto the trailer so I could get it home but my autox day was finished.
I have yet to disassemble the rear diff to have a look inside but can imagine that I will find bits and pieces of the internal gears everywhere. Will take pictures when I do get it disassembled.
So as a warning to others...when you launch hard at a light, drag strip, autocross run, etc. and you start to get rear wheel hop...do yourself a big favor and back off the gas, otherwise you will be getting towed home!
