You mean to change the time? If so there is a button with a little clock on it. Press that, then press the button under whatever you want to change, hour, minutes, etc.. then turn the dial to raise or lower the value. I think that's right. I remember it was pretty simple.
yes, yes, yes, me bad!!! I ordered a second owners manual from ebay so i can leave it at work and read it on spare time. Fixed the clock too. Thanks guys
I have 2006 with a basic radio / cd player. NONE of the above-mentioned clock time-changing steps work. Nor does the info in the on-line owners manual. With the key in the ignition in 'on' it should all work. The dials and buttons do not respond at all. I will post when I dig up the correct info for this radio.
Is there anyway of checking out the ONStar mic other than subbing from OnStar or removing the A Pillar to inspect .I have an 07 Sol with priemium radio ONstar in mirror.If I press the button on the steering wheel ,the radio muts but can not give any voice commands.I have not turned on OnStar...
Thought I'd share some pics of an audio install I'm in the middle of. So far, I've spent well over a week on it, several hours a day, and still not done. But I'm slow, so there's that.
Equipment:
headunit- Kenwood DDX9906XR
amps: Kenwood Excelon 5 channel, 4 channel, and a cheap Soundstream...
So I installed LED's everywhere in the car; the headlights, fog lights, tail lights, license plate lights, back up lights, trunk light, and the 2 rearview mirror lights. After having the lights all converted for about a month and a half I happened to be walking through my garage over the weekend...
I got my low mileage 2006 Solstice about a month ago. I cannot reset the clock or program (set) stations on the pushbuttons.
Is there a connector between the radio and the display that would cause this if it had one or more bad contacts in it?
dleach
Fair Oaks, Ca
Ok so i just got this car and I love it! Everyone has a phone and if your new to a city like i am to Houston you need a GPS to get around. I do plan on upgrading the head unit and adding a backup camera, but that's later. I am pretty good at sketchup and 3D design, so i came up with this design...
A forum community dedicated to Pontiac Solstice owners and enthusiasts. Come join the discussion about performance, modifications, troubleshooting, maintenance, trade parts, and more!
