1 - 2 of 2 Posts
I have done this many times on racing and riding motorcycles I have owned. Assuming the Solstice badges are mounted like those on bikes with a very strong two sided adhessive tape this is how:
Using a hair dryer heat the badge and area immediately adjacent to the badge. Take a length of dental floss, will not scratch finish, and holding both ends of the floss pull it down, working back and forth, behind the badge. Reheating may be necessary. You can remove any sticky left with WD 40, or paint thinner. May need to loosen with fingernail. Hopefully your floss will slide behind the badge tape and the car and not between the tape and the badge in which it may be clean underneath. Really not hard at all. Just takes a little time and working slowly and carefully is important. Chuck.
1 - 2 of 2 Posts
