1 - 4 of 4 Posts
Hello!
I am selling some rare 5x110 wheels. I am located in central Illinois.
I am selling four HRE 447R in 19*8.5" size with tires. These rims retailed $987 per corner when new. These are true 5x110 pcd with 65.1mm hub diameter, with offset of around 40mm.
The rims are truly one of a kind genuine, forged three-piece HRE 447R rims. Wheel centers (spokes)have brushed appearance under, and is protected by clear coat. Outer lips are polished. Wheel barrel is in a clean condition with some wheel weight sticker marks.
Bolt pattern is 5x110 (custom made), and will fit Cobalt SS, Saab 9-3, Saab 9-5, Ion Redline, Saturn Sky, Pontiac Solstice, Pontiac G6, G5 with five bolt patterns. I planned to get a Saab 9-3 Turbo X in black to match up to these special rims, but ended up getting two different cars instead of the Turbo X.
As you can see, rims are in quite a good condition. It was only driven in the summer. Two rims have scratch on the lip, but I was told that it could be repaired. One rim has a repair on the inner barrel from a minor bend from hitting a pothole, but it was professionally repaired and it is hard to distinguish the repair. The damage was very minor, and it balanced out perfectly, so I opted to have it repaired instead of having the barrel replaced by HRE.
Tires on the wheels are Falken 452 in 235/35/19 size. These are slightly taller in overall diameter than 225/45/17. Tires have camber / toe wear in them, and you can expect approximately 7/32" of tire tread left on two, and about 5/32" on the other two.
I am asking $1699;
I will respond to reasonable offers. I am willing to ship for right price.
http://i.imgur.com/UNZCL.jpg
http://i.imgur.com/855RT.jpg
http://i.imgur.com/z1yTr.jpg
http://i.imgur.com/yYbLw.jpg
http://i.imgur.com/ebSXM.jpg
http://i.imgur.com/5TrXr.jpg
Other set:
BBS RK II 17x8 Rims for Saab, Cobalt SS, Ion Redline, and Pontiac Solstice & Saturn Sky. These rims have 5x110 pcd, 65.1mm bore, 35mm offset.
This listing is for a set of rare BBS RK II rims, genuine 2-piece BBS rims with about 2" of polished lip. The offset is at 35, and in all of above cars, it will be close to the edge of the fender, but without rubbing for providing "filled" look.
The rims are 5x110 bolt pattern, and comes with three Saab center caps. Minor curb rashes are present on a couple rims, and clear coat on the polished surface needs to be refinished to restore the look again.
One rim has a minor, barely noticeable bend on the edge of the inner lip that does not affect performance. I was told that it would be repairable, but the professional shop indicated that the wheel balanced fine and does not warrant a repair.
Price is $399 obo for the four rims. I may be willing to ship.
Do you know the wheel weight??
Tread life left?? 10k miles?
Thanks
HRE's are gorgeous!!! HRE headquarters is right next to where I live. If they were 18's I would take these off your hands. Great Price!
1 - 4 of 4 Posts
