1 - 20 of 261 Posts
I uhhhh messed up. Removed the top of the air filter case and this nipple broke. I don’t know what this pipe is called but if anyone knows the name, and where I can buy a new one, that would be awesome. Thanks in advance for your help.
Motor vehicle Hood Automotive tire Automotive design Automotive exterior
Automotive tire Finger Synthetic rubber Automotive wheel system Auto part
· Administrator
If you want to repair what you have you will need a 1/4" drill bit and about 1" of 1/4" copper tubing.
Drill both broken parts about 5/8" deep, then push them together over the tubing.
I did a "temporary" fix in this way a couple of years ago, and it is still an invisible repair.
Discussion Starter · #7 ·
I did it again :/
removing wires and hoses in the way of the thermostat housing I broke this plastic part that allowed a wire and what I assume is a sensor to be bolted to the engine (I really shouldn’t own nice things) anyway, I don’t know what this thingy is, or what it is called and need a name so I can search for a new one.
Automotive tire Finger Gas Auto part Nail
Motor vehicle Hood Automotive tire Automotive exterior Vehicle
That is probably one of the only sensors I havent replaced and i dont remember what it is called.. exhausr camshaft sensor maybe?
Be very careful with the coolant temp sensor.
It is very easy to break.
Its is the gray connector with the big silver heat shield on the bottom left of your second photo.
Discussion Starter · #9 ·
[QUOTE="HHGadget, post: 2295709, member: 24859"
[/QUOTE]
Thank you. I wasn’t aware of that. This is my first time rummaging around in this engine bay, what other parts should I be weary of due to fragility, ability to add time to a project and/or their material make-up of unobtanium?
Anything near the cat and turbo exist in extreme heat conditions.
i broke my coolant sensor putting it back in. You do not want to utilize the plastic parts for tightening or loosening. Only use the parts meant for a tool and mostly you should be fine.
Take it easy and take your time. If something feels like it is going to break, take a moment to pause before going at it hard.
These cars are 13-17 years old and plastic and rubber components are going to have aged and become more delicate than a new part would be.
i think that part is the exhaust camshaft positioning sensor.
Discussion Starter · #12 ·
Research would suggest you’re right. Research would also suggest I done f**** up.
Also, I’m my defense (though I do admit to needing more patience) the sensor/connector above it was made of metal, and was stuck to the block. Took it off wedging a flat head under it. When I got to this one and it too was stuck, and out of sight, I (wrongly) assumed another metal connector and just yanked with the flathead. Lo and behold it was in fact, not metal. Too bad no one was there to see my face when it snapped off.
It is hollow and slides up the cable away from the sensor.
Performance autowerks (PAW) sells new ones if it breaks, it is just a heat shield
Haha. Sh!t happens as they say. Lord know i have broken a thing or two working on my car
Check this post by @kgschlosser :
Discussion Starter · #19 ·
Oh that’s glorious thank you
Discussion Starter · #20 ·
I don’t know how anyone gets the three 10mm bolts holding the thermostat housing off without removing the cat. I no zero tools that can make that twist to the bolt. I’ve gotten about 80% of the tear down done, but now without the turbo and car removed this seems hopeless and I have no clue what I’m doing. Been staring at it for hours and can’t figure out where the turbo is connected and what all needs to come apart in order to see it’s removal.
1 - 20 of 261 Posts
