Did you remove the plastic cowl in front of the windshield?I don’t know how anyone gets the three 10mm bolts holding the thermostat housing off without removing the cat. I no zero tools that can make that twist to the bolt. I’ve gotten about 80% of the tear down done, but now without the turbo and car removed this seems hopeless and I have no clue what I’m doing. Been staring at it for hours and can’t figure out where the turbo is connected and what all needs to come apart in order to see it’s removal.
"If" you are still taking the turbo off, and then removing the thermostat housing, you will be able to rotate it slightly once off the block to get a better angle at that rear bolt on the thermostat.Did you remove the plastic cowl in front of the windshield?
If you do, please follow some threads on the forum for advice as it is a part that is easy to remove, but there are caveats as to "how to" without breaking something. Most specifically the clips that go under the windshield and the plastic christmas tree fasteners that you need to open the doors all the way to access.
Also, many folks have struggled with removing the windshield wiper arms. I found that by gently pushing down on "elbow" portion of the arm to get it more flush to the windshield i was able to easily wiggle them up and off the geared posts they mount to.
I’ve got these completely removed. I did struggle a bit with the wiper arms but they came off once I got the right tool. I’m just unable to get at the 10mms holding the thermostat housing on. Between it’s own pipes, the exhaust manifold and the cat I can’t reach the bolt with any known tool.Did you remove the plastic cowl in front of the windshield?
Parent’s place in Harrisburg PA. I live in Daytona FL but won’t be driving back till this car runs. That being said, I did get the thermostat housing off thanks to help from several people and am getting ready to attempt the water pump. Not yet ready to tap out. (That usually occurs after I royally blow it)Where are you located? Maybe someone can help
LewisberryI live right outside of hbg PA
I’ve seen bothBilly, I assume you've seen DDMs instructions that explain how to change the water pump? They also cover the thermostat replacement in there.
Or this...
I did manage to finally get it off. It does have three 10mm bolts as well as the bolt for the coolant line to the turbo and the bolt that holds the electrical device in.Billy, you stated in post 20 that there are three bolts on the housing but I believe there are only two bolt. Should be a straight shot with a ratchet, extension and a 10mm socket. Could you maybe post a pic showing the issue you are running into?
Oh this is a helpful diagram though I’m stealing thisI misunderstood. I thought you were trying to change the thermostat which would require the removal of #14. You went deeper and removed #9 as well.
I stand corrected.
When you put the WP back in make sure you line up the colored links on the chain with the marks on the balance shafts and crank gear
