1 - 4 of 4 Posts
Hi Gents,
Let me apologize ahead of time for the newb question, but I need help identifying which flywheel I need. I'm putting the LNF/LDK in a kit car with an aftermarket transmission and throw-out bearing.
I received these pictures form Aasco. It shows their two ecotec flywheels that might be what I need. As best we can tell the two designs have the same pressure plate interface dimensions, but clearly one is thicker than the other (probably for a dual mass flywheel replacement).
P/N and description from their website:
- Left = 101217-11: '07-09 Solstice/Sky 2.0L
- Right = 101218-11: '08-09 Cobalt 2.0L turbocharged
So, which one is the right one? Is it that the cobalt has a single mass flywheel and the solstice/sky use a dual mass flywheel? Is there any reason the cobalt flywheel could not be used in a RWD application?
Thanks,
Daniel
*edit* DOH, I forgot to attach the pictures....but it looks like the forum won't let me. So, go here: http://www.cobaltss.net/forums/2-0l-lnf-performance-tech-153/identify-flywheel-316512/#post7513001
Discussion Starter #2
Well, for everyone's information I've more or less answered my own question.
The Solstice/Sky use a dual mass flywheel which is why it's thicker (flywheel on left of picture). The cobalt (FWD applications) does not.
Both of them will bolt to an LNF/LDK so I have the freedom to choose one.
For those of you using lightened flywheels, have you experienced any ill effects by eliminating the dual mass stocker?
Thanks,
Daniel
Thanks,
Daniel
Thanks, TurboWood.
Yogi
I have a Spec aluminum flywheel on my LE5. Revs a up and down a bit faster (better throttle response), haven't noticed any bad side effects.
1 - 4 of 4 Posts
