1 - 4 of 4 Posts
OK, I'm installing a new Alpine nav unit, and my handy GMOS-LAN-04 gives me zero reverse signal. Nothing. The line is always 0V.
OK, I figure I'll tap into the backup lights (which I've already done for my auto-dimming mirror). Damn thing gives 12V for reverse sure enough, but it's got 2V at rest! My stereo thinks it's always in reverse!
Anybody got any solutions for me?
As a secondary problem, I bought the ASWC for steering wheel controls cuz it should just plug right into the GMOS-LAN-04 and work. It doesn't. The volume cranks up to max, and the volume buttons seem to trigger OnStar. I think the harness might actually be wired wrong from Metra, but I'm just disconnecting this for now.
Thanks
Matt
Two easy thoughts come to mind, a relay and pull down resistor added accross the reverse bulb or maybe even easier add a couple diodes in series and a pull down resistor. (Each diode has .7 volts drop accross it.) PM me your email address and I'll draw it up for you with some radio shack part numbers.
Before you go down the path of fixing a manual reverse signal, are you sure that your GMOS unit is fully working? Not getting a reverse signal and not working with the steering wheel unit, definitely suggests smoke (if not fire). Try calling up their tech support.
Agreed ,smoke comes to mind right away,disconnect that part before something nasty happens and you will then have more problems then you bargain for.
1 - 4 of 4 Posts
