Hey folks, good evening. New "project" I had on the works.
I recently changed the oil for the first time since I bought the car and it was my plan to change the air cleaner at the same mileage as the oil and keep both as items to be serviced at the same time always.
But the engine air filter is not sold anywhere in Brazil which would mean importing a very inexpensive item and shipping and duties would end up costing more than the filter itself.
So I took a DDMWorks Mazda Miata aluminium intake tube kit I had bought and never used and pieced up a "CAI" (maybe I'll just call it AI) with a K&N oiled filter and found a way to fit the stock MAF sensor without needing the custom milled sensor "bung" to be welded into the intake. I used a VW MAF filter housing.
It's late here now, so I'll put the intake into the car and test it tomorrow. I believe it'll work well and maybe won't give me any troubles even using an oiled filter. The filter comes pre-oiled and the amount of oil on it is minimal, plus the MAF will sit quite a ways far down the pipe from the filter.
Tomorrow after testing if it works I'll report back here.
Here's the VW MAF housing, part # 06J.906.451:
