1 - 6 of 6 Posts
I currently have the BSR tune and hit 22-23 PSI under full throttle. The other day I went to give my car gas and no boost. I carefully drove it home a couple of days ago and discovered the rubber hose came off the intercooler on the hot side. This has happened to me on the cold side before so I have replaced all the worm clamps with the spring loaded clamps. I put the hose back on and tightened the clamp and the car drove fine until today. After driving it for a while I went to give it gas and at around 10lbs of boost, the car slowed down, the boost went down, and the CEL started flashing and then went out. I checked all the hoses and let it cool down for a while. I drove the car home and about halfway there, I stepped on the gas and the same sequence of events happened again. This time the CEL stayed on. I pulled the codes and they were P0101, P0300 and P0303. I double checked all the clamps and they are tight. I looked at the front of the intercooler and didn't see any swelling. How can I pressure test my intercooler without taking it out of the car? Could this be something else? Any ideas or suggestions would be appreciated.
here you go sir! this is an awesome show, and helpful as well!
Thanks for the video link. I will make the tester on Friday !!
Thank you great vid.
LLLFLY
1 - 6 of 6 Posts
