1 - 19 of 19 Posts
2008 Pontiac Solstice GXP
If you have TC (Traction Control) then yes. and the competitive mode only effects how the traction control functions. Press the TC button once to enter competitive mode and then a second time to disable TC. If you have ESC (Electronic Stability Control) if you press and hold the TC button for 5 seconds will disable both TC and ESC
No. The 2006 does not have traction or stability control, so there is nothing to turn off.
Does any NA Kappa have the "Competitive Mode"? I don't think they did, but not entirely sure. DAVEOC has good info in the following thread. Now knowing that most NA's don't even have TC.
Bert
Bert
Competitive Mode (as I tried to say in the post you quoted) is simply turning off Traction Control and Stability Control. It doesn't add anything, so if you do not have TC and ESC you are always in Competitive Mode.
  • Haha
Reactions: agent008
Yes I understand that, but the GXP highlights that as a feature. Let me re-phrase my question for you only. With the NA cars that do have traction control (and as I learned not many do), and you turn it off, similar to a GXP Model when it displays competitive mode on the DIC, will the DIC in the NA also display the message "Competitive Mode"?
Bert
And not entirely true either, as "competitive Mode" on a GXP still retains some control over the car. Perhaps "ESC OFF" on the GXP would be more in line with the NA with no control at all.
Bert
On my 2009 N/A Coupe, the DIC does Display "competetive mode" when I turn of the Traction control. Just FYI
Reactions: agent008 and JohnWR
Bert
I have never seen a 2.4 with TC/ESC, and have not heard of anyone who has one, so the short answer is "I don't know." Logic suggests that it would, but logic doesn't always count.
Edit: See above post by @cammerjeff . Logic does sometimes prevail.
I am curious abut why you are interested. If you have it you can find out for yourself, and if you don't it really doesn't matter. Are you just curious?
Bert
The manual is actually a bit vague about what the modes are.
  • Traction Control can be turned off with one button push
  • TC and ESC can be turned off by holding the button for 5-10 seconds
  • Competitive Mode is entered by pushing the button twice in succession
There is no clear description (that I have seen) that differentiates Competitive Mode from Traction Control Off, unless ESC is operating at a lower level.
I haven't done any real testing of the performance limits in any of the modes, but I'm certain that someone has.
Thanks Cammerjeff. Interesting.
John, simply out of curiosity. Over the years I do not recall ever seeing this discussed on the forum (s)(fora), regarding the NA. Other than that it does not pertain to our (My wife's) GXP. Which is why my search was brief and not extensive. And you are correct, the manual is vague, as well as the consensus of discussions over the years
Cheers
my 2009 NA coupe window sticker lists Traction Control
Bill
This driving option became available on the Pontiac GXP and Saturn SKY RL when they came out in 2007. Then in 2008 that control button at the bottom of the center dash began appearing in all the SKYs as a standard feature. That button up on the Sol boomerang became a standard, or at least an option, at that same time.
Cheers
Curiosity may be the best reason, and i guess that makes you a philospher, (From Greek: phlein = love, sophos = knowledge) or one who loves knowledge.
Bill
Now I have heard of two people that have it! But i still haven't seen it .....
Interesting that both people who have posted their N/A with T/C are both coupe's I wonder if it was standard on all coupe's . As my Coupe was pretty basic to start with the plastic steering wheel with no radio controls, plastic gear shift knob, and cloth seats. But it did have A/C.
It would be interesting to look up what was standard on a N/A Coupe, like did they make a coupe with manual windows, or no fog lights? I know they made at least 1 with no A/C (the minty Green Canadian Spec car now F/S in Florida)
ESC was beginning to be mandated by the feds in 2009. Probably why it began to trickle in.
Competitive mode does indeed turn off traction control, and raises the limit for yaw rotation before stability control intervention. Though I've admittedly never done a long rolling burnout with competitive mode active to see if there is a limit to traction control re-entering the conversation. Perhaps when my next set of tires life out I'll have to do that. For science.
Reactions: HHGadget
The owner's manual states "full control of the rear wheels", so i would say no limit, but don't let that stop you from testing.
1 - 19 of 19 Posts
