1 - 4 of 4 Posts
still trying to find out "WHEN" this is my vehicle order #-JCQTOD; this is my vehicle order history;2005-04-15 eff. date; end date2005-05-25 event code 1100 this preliminary order accepted procees id pz95vw; then event code 1101,preliminary order added, effective date2005-04-15,procees id#pz95vw; next, order re-edited code 2030,effective date 2005-05-05 end date 2005-05-05,proceess id fzgxy3 ; next, event code 2030 order re-edited effective date 2005-05-10,end date 2005-05-10 proceess date fzgxy3 ; next, event code 2000 accepted by gm effective date 2005-05-25 end date 2005-05-25 proceess id vz42kc; next,event code 2500 preferenced effective date 2005-05-25 end date 2005-05-26 process date 0m0pov005; next, event date 3000 accepted by production control effective date 2005-05-26 end date 2005-07-12 process id omopvoo5; next event code 1101 preliminary order added effective date 2005-07-12 end date 2005-07-12 process id 0m0pv005; next,event code 3100 available for sequence ,effective date 2005-05-12 end date 2005-07-12 process id 0m0pv005next,event date 3300,schudeled for production,effective date 2005-07-12 end date 2005-07-12 process id 0m0pv005, nextevent date 3400 broadcast effective date 2005-07-12 end date 2005-07-13 process id 0m0pv005, next event code 3100 available to sequence effective date 2005-07-13 end date 2005-07-20 process id 0m0pv005, next event code 3000 accepted by production control effective date 2005-07-20 no end date process id 0m0pv005!!!!!!!!!!!! :willy: :willy: this all my dealer has :devil: no explanation he just cannot tell me :( can anyone give me any good news about my first 1000 pure Sol????? thanks
Hopefully SD can give you some insight but as far as I am concern, my RED and your WHITE will probably be the last produced, that is why my target date has always been October.
Good luck.
This is similar to what happened to me.
The code numbers went backwards. Meaning your order got pushed out.
There were the original order dates in May. Then dates around 7/12. Then things went forward and backwards. But you have not moved forward again (I have) this is not good for you. You must hit code 3400 to be at production status and even that does not mean you are being produced on that date
just that the factory has accepted the order and can build it when the time is
right.
If you have not checked since last friday with your dealer I would. It seems
codes get updated late each week.
Sorry we all are playing the waiting game.
1 - 4 of 4 Posts
