So I got home and put my car in neutral, applied the parking break and went to pull the key from the ignition and it wont release at all. It will turn forward only. Since the key was stuck and car was still running, the only way to turn it off was to pull the ignition fuse(15amp) from the fuse box out. That worked but my key is still stuck! I'm now trying to disconnect the battery to see if it will reset the ignition locking mechanism. Anyone know how to fix this? Is this the ignition assembly that needs to be replaced or the ignition tumbler? Don't know why it would do this. Car is a 5 speed GXP standard with only 31k miles on it.
I did a search and some one said there is a release button under the steering column? Will this release a stuck key?
