1 - 3 of 3 Posts
It looks like I have a leak in the rack and pinion steering assy seals. Has any one else had a leaky rack and pinion? How much of a job is it to reseal it?
Sam
Depends on what is leaking. No seals are shown on parts list which usually means they expect to replace the unit. If the leak is where a line enters then an O-ring might do it. If the leak appears to be internal then it's probably a take it off, take it apart and see what you can find. Nothing to lose since you'd have to replace it anyway.
1 - 3 of 3 Posts
