Got the LEDs installed. They went in without any major issues. Only thing I had was a bad grounding connection on the Bluetooth module. Fixed that and it works great. Here are a few pictures:
1st one is the rear of the headlight assembly where the lamp is secured. I have the old lamp setting in the socket and the new LED lamp pictured in my hand.
2nd pic is the LED installed. The old lamp had a thick red rubber gasket that needs to be removed because the new LED had one already installed on the lamp base. Took a few tries to figure that out. After removing that it just snapped right in, no modification required.
**Adjusting the lamps: I got lucky and the lamps did not need adjusting. The beam was just below the 4' mark on wall in front of the car I had on my garage WHEEEEW!
3rd and last pic is of the bluetooth module and where I hooked it up to the battery and ground.
Routing and securing the wires was a snap. They supply a few zip ties BUT you will need way more. I also used black electrical tape to back up the zip ties. I zipped them to the existing wire harnesses on each side that follow the wheel wells where the headlight connectors come from and routed them to the firewall where I have the bluetooth controller mounted near the battery.
Trying to keep the wire out of "hot spots" was a challenge but I think I got it.
The APP "happy light" is what controls the features on the LEDs. There is a QR code you use to download it. If you don't "DO" QR codes you can go to the google store and search for it. Once I got the grounding issue fixed it worked great. Beats to music from the device the APP is loaded to and has many other cool features I am sure the wife will love.
You can turn on and run the LED portion of the lamps without having the car turned on.......FREAKY!!!
One thing I noticed was the LEDS stayed on when I turned the car off. That was not in any of the instructions and I had to figure it out.
Found you HAVE TO turn the APP 'OFF" and not just exit out. There is a power button on the APPs screen in upper middle. You have to press it and then the lights on the car will shut off. Dead batteries are no good! hehehe
Hope this may help someone in the future.
