1 - 6 of 6 Posts
So I installed LED bulbs for brake lights, yes they hyperflash. And I made the mistake of putting the resistor in the wrong spot (~$300 oops). So after thinking about this, is it possible to reprogram the BCM to modulate the speed the turn signals flash at without having to install resistors? Question 2: Can the BCM be reprogrammed to limit the voltage to the turn signals from the original setting so it won't throw a code (this would be fabulous as it would solve/answer both issues/questions).
not the answer, but i have vehicles that i have changed bulbs to LED and i refuse to add the resistors because of location and heat problems; SO i put up with the hyperflash because of their brightness
Bill
i believe i have read somewhere that the existing BCM cannot be reprogrammed because it is burned to the VIN. but its possible that an entirely new BCM can be programmed. but i cannot fully give you a 100% answer, as its a hazy memory. im sorry op i couldnt of been of further help.
I switched my turn signals to LEDs and installed the resistors across the hot and ground wires to the LEDs. Trick is to mount the resistors to some heat resistant surface. I mounted mine to the metal tray at the rear of the trunk right beside the turn signal.
1 - 6 of 6 Posts
