Yesterday while changing the oil I noticed there was a place to the inside of the actual lifting point that looks like it could be used with a jack to raise the car. It looks like a gusset with two holes drilled through, I assume this is where they would hook a chain to straighten out the frame if it was ever bent. Might be 3-4 inches towards the center of the car from the actual lift point. Reason I ask is I hate resting the car on the jack stands using the A-arm. May I ask how you guys raise the car and are able to get the jack stands where the lifting points are?
