1 - 8 of 8 Posts
Hi all, new to the forum. We just picked up an 07 with 9k on it, love it! while rummaging around the trunk area I noticed four little foam square tucked in the pouches on the very bottom of the covetable top corners near the base of the trunk. anyone know what these may be or why they would be tucked in where the were? They are about one inch square with sticky tape on one side, four on the left and four on the right side.
I believe these are to keep the fabric from laying flat against itself hindering water from draining down through this area. If you look all the way to the bottom I believe you'll see drain holes in the bottom to let water pass down and out through the bottom.
This is very common in convertibles. I helped a buddy when I detailed his Miata when I found the trunk was wet and checked it out on-line and in his car. His drains were plugged.
Welcome to the forum1
Discussion Starter · #8 ·
Thanks very much for the input, we went for our first "legal" ride today, WOW, iI wish we would have got one sooner!!!
1 - 8 of 8 Posts
