Yes...you're tuned. Only one side holds that sensor in...the bottom screw is just there so it's not lost. Find out where the plug was soldered now. Probably under that black electrical tape. From what I see, it looks like they're crimped under that electrical tape. Make sure it was soldered and not wire crimped together. If it's crimped, solder them together one at a time with heat shrink tubing and then re-wrap.
There is also another sensor up in the intake you'll have to do this for as well. The sensor should look the same.
