1 - 7 of 7 Posts
I'm curious is anyone has ever gone through Maricopa county emissions with an LS3 converted Kappa. I see that the Werks harness says it retains all of the emission readiness monitors which I believe is all that's really required to pass here. Just wanted to see if anyone's actually done the experiment.
I've passed a couple of LS2 cars in Phoenix and currently have a supercharged LS3 Coupe - I have not run the Coupe through recently as it is insured via Hagerty and does not require emissions test for registering. I might run it for kicks as I assume it will pass - all emissions equipment is in place, the readiness monitors are good and no CEL's, so should not be a problem.
Yes, Rob. I think that CO is more stringent than AZ, but it always passed here before it went to CO, even with the old LS-Edit software and tune. Running HP Tuners now and just had an updated dyno tune last week where all worked flawlessly. I have not driven it since this tune as a small crack opened up on the paint at one of the attachment points of the new hood scoop and I'm having that repaired (always something...).
What is required to run HPTuners?
Apparently something equivalent to a Ph.D. Over 400 parameters to learn about. I have not mastered it and I am an engineer.
If you have a V8 swap, it requires removing your ecm and sending to Dave at Werks to convert.
1 - 7 of 7 Posts
