I actually did think you meant LSX Matt. You said "one" of the best motors. Also, when it's used to mean ALL LS motors in general, it's written LSx. You typed lsx. Punctuation, capitalization and spelling DOES make a difference in getting your exact point across.
The LSX is an iron block motor.
The LSA charge cooler is different than the LS9 in that it has one solid cooler block instead of two separate ones like the LS9 and E-Force setups. The two separate blocks allow the charge cooler to be set a little lower.
The biggest difference between the LSA and the LS9? About $10k! It's very easy and much cheaper to get LS9 power out of an LSA. That's why the LSA is so popular, it's a lot of bang for the buck. ~700hp out of an LSA is relatively cheap and still bullet proof. The biggest differences in the LS9 are the titanium rods, dry sump and a bigger blower.
On my particular engine position and mounting, there isn't a vendor out there that makes brackets that I would have used. I've designed and made ALL my parts myself. (Except for the welding work, I have a welding company certified in structural welding doing ALL the welding on this car. If anyone wants to see beautiful and solid welds, they're on my car. I can weld, but I absolutely would NOT trust anyone but a certified welder for suspension, frame and brake parts.)
I won't get into the details of my build because I'm really not interested in giving away information to other vendors so they can use those ideas as there own and profit from them. Let's just say that there isn't a vendor doing Kappa V8 swaps that has the knowledge, expertise and attention to detail that is going into this build.
The engine is significantly lower, further back, and better supported.
The transmission/engine location is NOT determined by the location of the shifter, as is all the other swaps.
The TR6060 transmission uses the CORRECT for the LSA engine, fully stock dual mass/dual disk clutch including the master cylinder. The clutch effort is LIGHTER than the stock LNF clutch.
The shifter is an MGW billet C6 unit, supported by a custom made billet mount. Shifter feel and throw is insane.
The driveshaft is carbon fiber.
The ECM and BCM are STOCK CTS-V/LSA parts with STOCK calibrations. (My cruise WILL work!)
The exhaust manifolds and cats are OEM, they won't crack or fail.
The intake is OEM ZR1.
ALL drive accessories are new and exactly what would be on a '12 CTS-V. Actually almost every single component of this build is new, and 90% are OEM, down to the nuts and bolts.
The cluster is the exact one found on '09 to '13 CTS-V's. Complete with LED's that follow the speedo and tach and blink at the rev limiter. The information center (DIC) is fully functional. It will also have two digital, programmable OBD2 readouts built into the cluster.
It will have an onboard (in dash) fully functional Windows based touch screen computer for audio (no stock radio, iTunes for music with USB interface for amps), theft deterent system, logging and tuning, WiFi and video cameras.
It has CTS-V Brembo's on all four corners, with separate Brembo park brake calipers controlled by the CTS-V electric parking brake controller. It also uses huge OEM brake rotors from a Saab SUV.
And best of all... It will be CALIFORNIA SMOG LEGAL.
There isn't a vendor out there that has made a V8 swapped Kappa like this, I can guarantee that. That's because there isn't one that knows what I know. None of the vendors do their own ECM's because they don't know how. None of them know how to wire up or program the BCM's correctly. I don't believe any of them have made a smog legal V8 swap, much less a California smog legal V8. None of them have built an entire swap, including interior work, suspension work, paint work and ECM/BCM/computer programming/tuning work entirely themselves. Except for the welding, a couple parts I bought from a couple vendors, a radiator I had Griffin build, the driveshaft and the heat exchanger, this build will be all built with my own hands.
So honestly, why would I share details with other vendors of how I've done things on this build when there's practically nothing they've done for me? One vendor has caused me nothing but headaches and disappointments. So sorry Matt, I'm not going to get into the details of how my engine is mounted. Sounds harsh, but that's the way it is.
