1 - 7 of 7 Posts
I purchased a used LV brace from a forum member, unfortunately the mounting hardware wasn't included so anyone know what bolts and sizes are used?
Also were installation instructions included w/purchase?
You use the bolts that are already there. Unplug the connector that goes to the fan. Take the bolts out of the frame. Install the brace. Torque top bolts first. Side bolts second, and then plug the fan back in. Enjoy.
There is a small "D" on one side of the brace signifying it goes to drivers side. Start with it upside down and rotate as you slide it through. My fan plug was not disconnected nor was it in the way.
The original LV brace did not have the D stamped on the driver side.
What it had was a white label with the words Driver Side.
good to know...i ordered my first just over a year ago and it had it. I ordered my second one few months back...thought I knew it all.....
LV should know....he designed or helped design it.
I designed the original and then turned it over to DDM.
1 - 7 of 7 Posts
