1 - 12 of 12 Posts
Listed By category: all plus shipping. All parts are used off my sky unless otherwise stated. my sky had 93k miles when these parts were removed. All parts guaranteed to work upon arrival. returns accepted at buyers cost to ship back
If you need something not listed please feel free to ask.
Air/ Fuel Delivery:
Stock 2.4 air box assembly $45
Custom red Aluminum CAI with filter $50
2.4 Throttle Body x2-$40 each
MAP Sensor 2.4 $10
MAF Sensor 2.4 $15
K&N Air filter 2.4 $15
Intake Manifold 2.4 $35
Fuel Rail 2.4 x2 $45 each
2.4 Fuel pump assembly $75
Ignition Parts:
2.4 coils 2.4 x8 $7.50 each
2.4 Crankshaft Position Sensor $10
2.4 Camshaft Position Sensor $10
2.4 Knock Sensor $10
Exhaust/ Turbo
2.4 Manifold $25
Custom WERKS T3/T4 turbo manifold $275
TIAL 38mm red wastegate $125
TIAL Red BOV $125
Disassembled Precision 5031 Turbo Needs rebuild kit $150
2.4 WERKS/Precision aluminum intercooler $150
Walbro 255lph Fuel Pump $25
ProSport Oil Press Gauge $20
ProSport Boost Gauge $20
2.4 PCM with WERKS stage II reprogram $175
Engine/ Misc
Valve covers 2.4 x2 red/stock $40 each
2.4 Harmonic Balancer x2 ps $20 and non ps $10
2.4 Radiator Manual Tranny $45
2.4 a/c condensor $20
2.4 Oil Pumps x2 $25 each
Alternator 2.4 $30
Starter 2.4 $30
2.4 Power Steering Pump & Resevoir $ 65
2.4 New Power Steering Pressure Line $40
2.4 Idler x2 $20 each
Transmission/ Drivetrain
Flywheel Manual 2.4 $45
2.4 Aisin 5 Speed Transmission $250
2.4 Driveshaft $75
2.4 Slave cylinder <3000miles $ 35
2.4 clutch kit < 3000 miles $35
Transmission Skid Plate $20
Speed Sensor $25
2.4 FE2 coilovers < 50k miles$55
2.0 FE3 coilovers < 50k miles $100
Redline 2.0 Gauge cluster $50
Accelerator Pedal Stainless $ 35
Accelerator Pedal Black Plastic $15
2.4 Long Block with 93,000 miles $ 175 or will part out by request
Reply via post or PM thanks. no email as I don't check it often enough
Brian
easy question....you still have the car..or is it broken apart for sale ??
I'm interested in the following:
Is the PCM an n/a program? (I ask because you have a lot of turbo stuff listed)
Interested in the 2.4 exhaust manifold. How many miles? And do you have the catylatic converter also? Thank you.
anybody heard from brian?
1 - 12 of 12 Posts
