1 - 20 of 39 Posts
So here are a few pics of my mini truck build. I have decided to go with a 4 door body. I got a deal on a fully loaded 2000 frothier with a motor that has skipped timing but that doesn't matter since all I need is the body. I'm also replacing the bed with a longer one.
Discussion Starter #2
Got my Toyota hubs for my 5 lug conversion
Got my Belltech Toyota drop spindles for my conversion
Colorado Customs steering wheel pinstripped blue and silver
Got all my wilwood rotors today. I'll be running them and the calipers on all 4 corners. I have them and the rotor hats on order.
My Wilwood rotor hats
Wilwood calipers
Finaly got my new I-Level from accuair
My new ZZ4 350 with TCI transmission
Got my valve covers today
Got me my new Holley fuel pump
Fuel filter
Bought my clear view thermostat for my V8
Got my painless wiring harness. It's alot of wires lol.
My new Edelbrock 600 Cfm carb
Who doesn't like getting go fast parts in the mail
Timing cover and intake gasket
Edlebrock intake manifold
Comp Cams Springs
Comp Cam
Edelbrock Air Cleaner
Nothing special just the Comp Cams retainers/locks
I just bought some Gmc Terrain power and heated seats. Hopefully we can get them to fit.
Installed the cam, lifters, springs and retainers. Had to order a better adjustable cam gear and a rebuild kit for the TCI. Then after all that stuff comes in we will install everything else.
Finish building the motor just have to buy my pullies and accessories now
Discussion Starter #9
My parts for my 9 in ford came in today.
My ford 9in housing
Discussion Starter #11
Got my Msd Ignition
SBC Motor Mounts
Discussion Starter #12
Here are pics of my air suspension parts/air management
Re-7 Air bags
2 Viair 480 compressors
5 gallon Air tank
Compressor wiring
Accuair Air Management
Discussion Starter #13
I'm in the process of tracking down some frontier front end parts so I can change over to the 2001 and up front. I have found a hood and just picked up these lights today.
Discussion Starter #14 (Edited)
Here are my outside and center vents for the dash from restromod air. They aren't that cheap plastic they are metal.
Discussion Starter #15
Finished the motor today with all the new expensive march performance pullies
Discussion Starter #16
My restromod air ac unit
Just bought these for my engine
Here is my compustar alarm with all the bells and whistles.
Discussion Starter #17
Lokar kickdown cable
Discussion Starter #18
So the bodywork will begin next month and the building of the frame will start in February
Discussion Starter #19
My Lokar gas pedal
1 - 20 of 39 Posts
