1 - 4 of 4 Posts
Hey Guys,
i have this kind of problem with my solstice , car have the performance autowerks turbo kit ,
runs perfectly under boost , but when it hits the rev limiter the car goes rich and throw a misfire code , while the car sounds like sabaru... i cruise for like 10 seconds the car goes back to normal state.
if i don't hit the rev limiter car is running perfectly...
the OBDII scanner says misfire cynlinder 3 , i took out the #3 spark plug and replaced it with #2.
tested it again , still same cylinder, so i don't think its a coil / spark plug problem.
any input ? ide appreciate your help ! thanks !!!
I suggest that you ask Werks - they built the kit.
The kit wouldn't have much to do with it...
the tune however...
1 - 4 of 4 Posts
