1 - 7 of 7 Posts
Read Only
For the past few months it seemed that my boost was getting lower or the GMPP tune was relearning, so after reading some post here on similar topics I decided to check any clamps associated with IC starting from the passenger side....all seemed good and tight and good quality clamps and I get to the last charge tube-still with the factory clamps......first one a little loose but snug and I tighten it up even more,finally the last clamp right under the TB.......hmmmm.... this one seems really loose I got 1/2 a turn and snap...:brentil:##@*#*@&&, of all clamps to fail it just had to be the one in a tight spot,.....GREAT! So for now I put on a normal hose clamp but I'll have to got and get a proper spring clamp during the week and install it, I haven't driven it yet but hoping that was the culprit for the loss of boost.
It getting cooler there? Ya, the air is denser then and requires less boost.
Or you had loose clamps.
Are the "spring clamps" necessary? Or are regular T-Bolt clamps good for this purpose? Did you find replacement spring clamps? I guess the auto stores should carry these spring clamps(Piston ring,Napa, auto source)
Bert
Read Only
only Piston Ring on Wall st. had anything close enough to the diameter that I needed Especially on a Sunday , but it was only a regular coolant type worm gear hose clamp. I'll go to Western Turbo and get the proper clamps. I noticed that a few of the clamps are already the spring type and were tighter than a .....(.....fill in the blanks___:D__)
Hopefully your map 3 bar sensor is solder and not crimped.
Read Only
Not really.
1 - 7 of 7 Posts
