1 - 1 of 1 Posts
Folks -
(1) If I haven't already called you or otherwise browbeat you into being a Run Captain and you would be willing to lead a cruise, please let me know asap. [The enthusiasts' runs are covered]. If we can't find enough run captains, we may wind up combining groups of the same cruise. We will only do that if absolutely necessary because it may make for large groups in some cases, but it may be unavoidable.
(2) When you check in, be sure and check the bulletin board and note your updated run times. The groups have remained the same (for now, see above), but the run times are almost all changed slightly, so we could: (a) make sure everyone is back for evening social events and (b) space the groups out a bit. I will also post the list here in the next couple days.
1 - 1 of 1 Posts
