1 - 16 of 16 Posts
I have a number of mostly over-sized parts I'd like to clear out of my storage area, and with NASSAM approaching I figured it might be a good time to see if anyone wants to pick anything up on their way there. I'm located about 20 minutes east of Lansing, MI, but if I sell enough I can also just load up my truck and deliver everything in one shot to Shanty Creek.
Flexible on prices, with increasing flexibility as you purchase more. My goal is to clear this stuff out without it ending up in the trash. I'm not trying to pay my bills with sales, but also not going to give too much away.
I apologize in advance that most of the parts are dusty, anything that sells will be cleaned nicely once I get it out of storage and before pick-up/delivery.
Door panels - Passenger has typical small bubble forming, Driver side is like new. $60 $40 passenger, driver side $SOLD
I also have some of the innards, if there's a switch or something you're after.
113137
113138
Fender liners, front driver side fender liner, GXP, or either side rear, all OEM $40 $20 each.
113139
113140
Wiper shroud $40 $20
113141
Fender brackets (these have some surface rust in spots) $40 $20 per side
113142
Tow Loop thingy $20 $5
113143
GXP floor mats w/ red stitching (The wear looks worse in the photos than in real life, I promise.) $60 $40. Can ship these as well.
113144
JBL speakers/tweeters for non-monsoon system (makes the base radio useable with the top down, no need for additional amps.) $40. Can also ship these. SOLD
113147
113148
More continued below...
Discussion Starter · #2 · (Edited)
Trunk carpet. Has small holes for coil over adjustment. Bottom $60 $20, top $40 $20
113149
113150
113151
Washer Fluid bottle w/ pump $40 $10
113152
Tulip panel, no flaps $60 $40
113153
Im looking for the drivers side door lock switch. If you have it how much?
It's there but let me confirm condition and operation tonight before I quote you anything.
Welp, the switch can't be separated from the door panel without cutting tools, which I can't do to a part I'm trying to sell whole.
Kind of explains why you can't buy just the switch.
And boy would I have been pissed circa 2009 if I walked into a dealer with a just-out-of-warranty car and been told this.
113162
In other news, I have the whole panel if you want that! :LOL:
Do you still have the panels???? I want to recover mine, but need a practice one so that I know what i'm doing first...LOL
Thanks but I think I found a work around with a new OEM switch for $25 that was used on the Malibu. Only difference is the label orientation which can be remedied by simply swapping the switch cover.
Hi, would be so kind as to share with us the part number for the Malibu switch? I'm wondering whether I could cut out my '06 door panel and fit a swithc to the same place as later models had them form the factory.
If I lived in the US would defnitely buy newer door panels instead of cutting mine.
Since I live in Brazil and would cost heaps to ship door panels (which one day I might be able and willing to pay if I find the better looking chrome accented Sky/Opel GT panels)...
I figured could buy a Door trim kit such as the one below, and use the kit's switch cutouts as templates.
113537
Are you wanting to match the OE look, or are you just looking for door lock/unlock function? Function is easy to achieve with a generic pushbutton and a resistor.
Yeah sure. So this is what I found on Amazon.com. Actually if you scroll down to the reviews on this switch a guy has already done the swap on his Saturn Sky. The two differences are the button cover, which he explains you can simply put the old button cover on the new one, and the led light color is white instead of red. To me that's not a big deal as long as I have a working switch again. I haven't ordered this yet and done the swap but I will after I work on some other things.
113542
113543
Matching OE look would be nice, and I especially planned to go this route because I didn't realize before there is a trim kit for '06 non-switch panels, so thought the open stamping for the switch on the trim kit, without a switch in it, would look lame.
I've found the lock/unlock retrofit thread here some time ago, so was aware it could be done with other switches. Actually my plan is to try it out first with a round switch that I'll install into the TC switch blanking plate. Later on this spot would ideally be occupied by the TC button itself (a big IF I manage to make it work) and then the door panel switches would come in handy.
Hang on, if you haven't ordered the Malibu part yet, I think you can get the correct(-ish) switch if you search for a Pontiac G6 switch. I asked you about which part you found, since the Sols/Sky ones come with a triangular backing to hold it in place, but of course if you're not adding a switch to your car like my case, you probably will get by with just a new switch - no need to get a new triangular backing, you can reuse the old one.
Here's the G6 switch from Dorman's website. Do note they list a GM part number for it (15777128) so you can also order AC Delco or OEM. I'm not sure but would figure this woul have the red lighting since that would be Pontiac's standard at the time?
113544
EDIT: Back of Dorman's G6 switch also looks compatible. Also forgot to add the URL: Dorman Products - 901-198
113545
Oops. The icon on the switch is still different. My bad. But maybe better than having "tumbled to the side" icons. Your choice
Discussion Starter · #15 ·
Bumping for new lowered prices. Also cross posting to facebook at this time.
1 - 16 of 16 Posts
