1 - 3 of 3 Posts
2006 solstice: in back of the seats on the deck, are two flaps, right and left. when you raise the roof these flaps open via a cable. One of the flaps cable broke. Before I bring it to the garage, the cable is about the size of picture hanging wire. Has anyone dealt with this, do I have to buy an assembly, can I use hardware purchased wire? Certainly appreciate your opinions and help. alread chipped some of the corner of the flap away exposing fiberglass which I'll have to repair
Generally the failure is not in the cable but in the plastic clip that attaches the cable end to the flap. There are a couple threads on this clip including part numbers etc. Its a very easy fix.
Part# 15290793 Called a "Bushing Coussinet" List $3.51, GM Parts direct $2.00
If you cable is broken, you can buy it as a line replacable unit from any GM source.
http://www.solsticeforum.com/forum/f12/convertible-top-issue-65507/
Saturn Sky Forums: Saturn Sky Forum - View Single Post - problem with trap doors.
1 - 3 of 3 Posts
