Hi everyone. here"s the problem. BLOWER MOTOR WORKS on work bench with 12 volts applied. Does NOT work when hooked up to the car. As far as I can tell fuses 10, 16, and 30 work. Did anyone have a similar problem? A/C clutch engages. Thinking it might be resistor pack. Connections do not look burnt. What is at the end of the resistor pack. Is it a diode or a resistor and does anyone have info on it as far as the value is concerened or any info so I can try to replace that instead of the whole pack. Also does anyone have a blower motor diagram for a 2006 Solstice? Thanks........ duke :willy:
