All flaps are identical. Pull yours so we can see pics and we can maybe offer some advice
You need to read the alignment manual. It's posted here somewhere and describes how to line up all the body panels
Is there a Solstice body alignment manual on-line that I can access?
I will temporarily install the driver-side tulip door and post pics later today on how it is misaligned. The picture I posted at the very beginning is the passenger side which is perfect.
About removing the tulip. I won't be doing it. Removing the tulip is more than just removing all those screws. There are adhesives involved at the two ends where the thick rubber stripping channels water. I don't want to disturb those critical things so I am working with the tulip in-place.
Though I had removed the interior back panel specifically to search for the clip, I am so glad it is out of the car because now with the seat belt slot removed, I have much better access to the coil spring area of the tulip door. I will take pics of that too.
About the inside door pillar and back panel removal...It took a lot of force to pop the retaining clips. In places where it seemed exceptionally tight, I carefully inserted a long & wide flat blade screw driver right at the clip and carefully twisted it to pop the retainer. Doing so was much less over-all tress on things.
Thanks Rob and the rest of you for all your on-line advice. I have been a PITB with all my little issues.
